Downpipe/decat differences...?
Glanza_Mike
Just make sure you make some form of brace, to help take the weight of the exhaust system, off the turbine housing.
All that weight hanging off a vband flange, doesn't fill me with much confidence.
I made a bracket to bolt the downpipe flange to my r154, to make it more rigid.
I can now undo my vband clamp, and the downpipe stays where it should
I made something similar that bolted to my old auto box, that I've recently removed
Edited by Mk4Gaz (see edit history)
I thought all supras came with a brace bar (exhaust to gearbox) as standard anyway?
Mine had one, and i also had one included with the R154 kit i bought
Youre right though it certainly helps having one
Hmm, I definitely didn't have one, but then my car already had a 1st decat fitted to the stock twins setup, so maybe the stock one was binned :rlol:
I made the one above when I went r154, as it's a sensible addition.
/QUOTE]
Quite possibly then
Number 10 in this diagram is the stock brace
https://parts.bernarditoyota.com/media/images/oe/collision/8/8494181.gif
Not sure if TT originally had them, but i guess so as my R154 came from a 1jz chaser which had one too
