mik3ysupra Posted December 4, 2016 Share Posted December 4, 2016 Right guys im getting abit desperate for help now i have put a 1jz into my mk4 supra and i have taken out my w58 box and swapped it for a r154 which has come from a jzx90 , everything is done apart from my prop shaft please can someone tell me what prop i need or if mixed what front half and what rear half from what car etc this is seriously driving me insane now [ANGRY][/ANGRY] this is the last thing to do and i can finally drive it home thank you Quote Link to comment Share on other sites More sharing options...
martincoupe Posted December 5, 2016 Share Posted December 5, 2016 Mk3 supra or manual soarer front or some shot fronts along with a rear to match your diff Quote Link to comment Share on other sites More sharing options...
ashloys Posted December 5, 2016 Share Posted December 5, 2016 I just saw your post under my build thread there dude. Tbh I can't answer you 100% as I used an R154 from a MK3 Supra, not a JZX90! Personally, I used the rear half of an NA 5 speed Supra, mated to the front half of an R154 MK3 Supra propshaft (but I had to use the NA5 carrier bearing, it just bolted off and swapped over). In your particular case I'm not of any help. The only other person I know that's done an R154 swap used a JZX100 R154 which again may be slightly different? TBH what you're best doing is just measuring the length the front half of it needs to be and take it to an engineering shop. It'll be cut/welded/balanced and that'll be your best bet. It'll probably end up cheaper than buying several different props from used cars and find out that they don't work! Quote Link to comment Share on other sites More sharing options...
berg Posted December 5, 2016 Share Posted December 5, 2016 Mine uses the w58 rear section and a JZX100 front section (JZX100 front section needs shortening by 40mm though as its too long) Mine is a late model gearbox though with the remote shifter from the JZX100 so not sure if the length of the box is any different to the earlier boxes Theres always 1 piece custom props available from places like driftmotion Quote Link to comment Share on other sites More sharing options...
