Ecu
snuf
Hi
It use to work up to about 6 months ago then it became intermittent and finally total failure. The light works when earthing the input pin at the Ecu proving the lamp circuit is ok. I did read that the immobiliser can cause this but I can't see any connection from the immobiliser Ecu to engine Ecu on the circuit schematic.
