An Fittings
chrispot
 Share
Hi all, can anyone confirm that a AN fittings use a 60 degree thread angle which i think it is, I have searched the net and can can't find anything to confirm.
Being a yank defined thread I assumed a 60 degree, same as there NPT fittings and our BSP is 55.
The reason for asking is i am making a AN fitting for a turbo oil pressure gauge. so when i fit my ball bearing turbo i can check pressure into turbo and adjust if necessary via hole size in restrictor then remove my adaptor. I know i can buy one, but why when i can make for nothing that's only going to be used once.
Thanks in advance
Regards Chris.
 Share
