a98pmalcolm Posted September 22, 2016 Share Posted September 22, 2016 Hey all, I'm going to fit a Sparco steering wheel single button kit for rolling anti-lag. But the kit also comes as a double button kit. So I was thinking the other button could be used for my PTT kenwood button which would be so handy rather than reach over on my dash. Now normal switch would work like : When closed earth - switch - earth When open (when switch pressed) earth-------earth switch But with the Kenwood PTT uses a button switch, so when you press it once it then asks for a voice command. The PTT button switch is connected to the headunit via a mini jack (like an audio one) Would the single wire that goes into the button switch be an earth, and when pressed there is a built in earth on the switch? Bit of a confusing one but any advice would be great. Thanks So I would like this button below to go into the sparco steering wheel button Link to comment Share on other sites More sharing options...
Burna Posted September 22, 2016 Share Posted September 22, 2016 (edited) If I've understood you correctly, you're after a 'momentary push button switch' to replace the latching sparco buttons? Like these? http://www.ebay.co.uk/itm/like/261161661277?lpid=122&chn=ps&googleloc=1007167&poi=&campaignid=661219804&device=c&adgroupid=33170564523&rlsatarget=pla-257284469200&adtype=pla&crdt=0 EDIT: Ignore me, I've just checked the sparco steering wheel buttons and they are already momentary contact. Of course they would be if I'd have thought about it for a second, you wouldn't have a horn button as a latched switch lol I'm having one of those days today :/ So it looks to me you could just wire up the PTT button to the Sparco button. Edited September 22, 2016 by Burna (see edit history) Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 22, 2016 Author Share Posted September 22, 2016 Yer I want to wire in the PTT button to the sparco button. Not a Problem IF its is an earth as I can snip of the stock button put the wire onto 1 connection and then a normal earth the other but I dont know if its going to work like that. Link to comment Share on other sites More sharing options...
