covering hole rear bumper
alibabba
Hey guys,
How did you cover the hole in the rear bumper behind the licence plate? I don't want to use the side pods.
USDM/EU spec bumpers aren't available anymore...
I'm using USA sized plates (I'm in the Netherlands), but they won't cover everything. There is a 1cm gap on the bottom.
Edited by alibabba (see edit history)
A bigger plate isn't an option over here. The plate/holder should meet legal dimensions.
Anyone tried fiberglass or plastic welding?
"Plastic" and "welding" should not be used in the same sentence ;)
So is the hole in the bumper larger than legal dimensions? Surely you can get away with a plate holder?
I swapped to a UK spec rear when i went to a usa size plate
/QUOTE]
That would be the best option, if you can find a second hand one. New they are discounted according to my local T-dealer, SRD & Whifbitz.
I ordered a plastic carbon sheet from eBay trimmed it down and it looks good
That actually looks really good. Mine is Moonstone, so I think carbon suits it well.
