berg Posted August 11, 2016 Share Posted August 11, 2016 Im buying all the parts to make my new fuel lines up and i now have everything other than the line from the filter to the rail (fuel pulsation dampener removal if you like) Im wondering if anyone knows the thread pitch etc of the adapter i need for the fuel filter? My lines are all AN-6 im just not sure about the thread on the filter Cheers Link to comment Share on other sites More sharing options...
Scott-tt Posted August 11, 2016 Share Posted August 11, 2016 There's a delete kit you can buy from filter to rail I think whifbitz sell one. There's a thread on here somewhere about it with the thread size/pitch Link to comment Share on other sites More sharing options...
berg Posted August 11, 2016 Author Share Posted August 11, 2016 Yep but its nearly £90 for something that costs £25 to make myself lol Ive found it now anyways Link to comment Share on other sites More sharing options...
Jellybean Posted August 11, 2016 Share Posted August 11, 2016 (edited) 45 degree Double Swivel fitting (To use on the Fuel Filter) and a 90 degree Double swivel fitting (To use on the Rail) , Outlet at the fuel pump hanger and the inlet for the fuel filter are 14x1.5 inverted flare , Outlet is 12 x 1.25 for fuel filter to rail, I have a top feed rail , that is a 12 x 1.25 too, should be the same on the OEM rail as I had the OEM Fuel pulsation pipe connected Dont forget some copper washers I would not bother unless you need to run over 600 hp as the noise without the pulsation damper is a tad annoying , you can hear the fuel gurgling Edited August 11, 2016 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
