Changing my Jap brakes To UK Help!
JCresswell
Hi All, i havent started yet but has anybody changed the brakes on there Jap car to UK spec??????, if they have could you let me know what sort of problems you had?., i would be a great help, Im aware of the backing plate being removed or bent out of the way but apart form that i have no idea what to expect?, lots of non supra owners have said OOOOhhhhh mounting plates for the extra disc clearance another said what about the master cylinder!!!!!!, anyway instead of listening to rubbarb can any of you help out and give me a clear picture,,,,,,, :baa: :moo:
Do a search for 'uk brakes', there is loads of info...
As long as you have big enough alloys (or stock 17s) it is a straight swap. Like you say, you will have to cut or bend the backing plate out of the way but that is it.
What to expect? Loads more stopping power.
Yeah i thought so, thanks !!! very much for your reply, i get fed up with know it all's putting there 2 cents in, I ordered the brakes from Airedale Toyota and they should be here within a week, gona put uprated pads on the rear and braided lines all round cant wait, only had the car a few weeks and its fab, brakes first then induction kit, then zorst, then a new IC, and maybe a Dump valve if i cant work out what the benifit is????
cheers
cheers
Yeah, i just had some braided brake lines fitted - tightened up the pedal loads.
What is the benefit of a dump valve? NOISE :flame Dev
Get searching, dump valves, induction kits, exhausts and IC's have been done to death...
Enjoy your new toy... :D
Hi and welcome.
I am sure you will find all the info with a search.
IMHO it is best to take the backing plates right of, use a good pair of tin snips or a grinder. You must check each disc on all five possible fitting positions with a runout gauge. While you are at it stick in a better fluid.
As you have not had the car for long it wont take long to get used to the new stopping power, unlike some of us who were pulling up too soon few a few trips;)
Thanks i forgot about the fluid probaly use DOT 5.1 and i think there is a 6??? fully synthetic isnt there???, i hope there as good as everyone says, i was motoring the other day braked hard from 120 (any police here???? it was KPH honest ) and missed my left turn:p :stupid: ive only ever gone fast on my bike before, as my last car was an old SAAB, the bikes shod with AP goodies so stopping wasnt a problem, but i have to say i never ever thought the supra TT (jap Spec) was as fast as this, I love it!
Thanks Guys,
Ive just mailed him, didnt know he was into racing etc......
PS another one for you, I know you said dump valves are nice to have for the noise, any idea what sort i should buy, there seems to quite a few around, i want the tissshhhhhh wizzz noise:p and are they easy to fit or should i leave that to someone like TDI,
Thanks Again
Use the search button, everything you need is there!
AFAIK the HKS BOV SSQV is regarded as the best dump valve for up to 18psi. Shouldnt be too hard to fit...
I've just pulled the pipe off the stock BOV that recirc's the air into the turbos and blocked up the hole, makes a pretty good noise and cost precisely nothing.
Have a look at these threads for dump valve stuff:
Which dump valve?
BOV and Induction
HTH
Guest Martin F
Damn nearly as helpful as me!!!!
:p
JC if you get stuck, I did this last year and photographed it all. First thing to do is check you wheels will fit over the new caliper. Take one J-spec off (leave the pipe connected) and remove the disc. Bolt on the UK caliper and try refitting the wheel. If it clears, you can proceed to dismantle everything, if not you need to sort clearance out before anything else.
Fluid; I use AP Racing Fluid available from Demon Tweeks via mail-order.
If you want any photos, let me know [email protected]
