Fuel Injector Ring
cushti
N/A engine, just changing rocker gaskets/plugs e.t.c, & looking down I saw this fuel injector rubber ring dried up & split at the bottom! No fuel leak but perhaps it explains why I can hear what sounds like an induction kit on the wrong side of the engine, doesn't seem to affect the running of the engine strangely, except for a very low idle for an auto (600).
I checked the parts cat & just want to be sure what to order (assume Toyota best to buy from for this). Please could someone confirm if what I need is called the 'injector vibration insulator' - 23291-46010?
Edited by cushti (see edit history)
Hi - thanks for the reply. I might well have to take you up on that but I only need one plus I don't know if I need the 23291-41010 or 23291-46010 as my model is 1993 & the dates cross over on the number I need. Does your set include both types then?
