Flat spot hesitation around high rpm
K22SUP
Hi guys my car when i accelerate hard after second turbo comes in had a stuttering holding back effect exhaust note changes from clear to burble if I gently appl throttle she accelerates clear hard to explain I have just changed all the plugs to bkr7eis few of the coil clip broken so they are all cable tied tight now and a have just been out and tried it seems a bit better but coil pack have obviously been turned as refitted now it feels bit better but I get like two stuttering flat spots at high rpm maybe around 4750 then it clears then it does it again then clears again not as bad as before the car has 1st cat removed second still in greedy front mount boost controller walbro fuel pump fuel pressure reg also all hard piped Hks 264 cams pulleys any ideas ? Coil pack timing out ? and recommended ways to test to get to the bottom boost is about 1 bar thanks edd
  • 3 weeks later...
Hi guys coil pack connectors now changed and still have a slight hesitation it's as if she goes then holds back then goes again when second turbo is in only I was hoping clips would fix it it's not major as in she drives through it but am back to drawing board for ideas plugs are done clips are done maybe a coil breaking down ?
the resistence can be within spec but still cut out on higere rpm.. mine did :)
yes mount them again, start the car and let it idle tage the spraycan and spray on the coils if you have a crack on the coils, you will hear the idle change, as it will misfire on that cylinder..
