Nos gurus needed?
T14PPA
Im thinking of fitting nitrous to my supra. Had it on my old bmw and loved it. Anyone using kits on their single turbo auto? Any advice? What shot would you run if its single point injection. Dont want mega power from it just a safe amount. Ive got a 10lbs nos bottle sitting in my room. But none of the other parts. Can anyone list what ill need and where to get them from for a good price. Thanks in advance
I was a Wizards dealer way back in my Thor days. They did a decent set of solenoids and bits and bobs for a fixed shot or you can run a maximizer to blend your shot in. Nitrous is fantastic for spooling your turbo up quickly. If you use it this way it tends to last a lot longer than an all out power adder.
http://www.noswizard.com/
Edited by Nodalmighty (see edit history)
I want it mainly to speed up the spooling of my turbo. As an ex dealer can you help me with a parts list mate? Without the bottle
What ECU do you have. If you have a stand alone which can configure an aux output with rpm and tps position then you need very little else.
Best case, a bottle adapter, Nitrous line to the solenoid, 1 x Nitrous solenoid and 1 x Fuel solenoid, relay, fuel rail fuel tap adapter for the fuel solenoid and an atomizing injector and the lines to it and from the solenoids.
Worst case you will need a maximizer to control the solenoids against TPS and RPM.
