uk-rich Posted September 4, 2005 Share Posted September 4, 2005 just removed this item, tomake some room under the hood for future mods, read some stuff about the car relies on the fumes to richen blah blah blah, runs just fine with out !!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Markie Posted September 4, 2005 Share Posted September 4, 2005 Have you blocked off the pipe to the intake mani and re-routed the fumes pipe to run out side of the engine bay? I run without one already too mate. Link to comment Share on other sites More sharing options...
uk-rich Posted September 4, 2005 Author Share Posted September 4, 2005 im thinking of using the one way valve off the breather on the canister, the one which comes out the bottom, to put on my fuel tank breather, should stop any evaporation with any luck ! Link to comment Share on other sites More sharing options...
supradibbs Posted September 4, 2005 Share Posted September 4, 2005 can some one do a diagram of what is removed blocked off etc as i want to mount my FPR there Link to comment Share on other sites More sharing options...
Guest GadTek Posted September 6, 2005 Share Posted September 6, 2005 if you go to mkiv.com there is a pretty good write up on where you need to run lines. It is popular to run the fume line to the intake pre-turbo, to keep the fuel smell down. Ron Link to comment Share on other sites More sharing options...
