Calorus Posted January 10, 2015 Share Posted January 10, 2015 Hi Chaps, Suffering from a very rough idle on a pre-facelift GE and one possible culprit might be the temp sensors. Only problem is I've no clue what appropriate vals for them might be. Could anyone help with test values at all? Cheers in advance! Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 11, 2015 Share Posted January 11, 2015 Andy Blyth, a well regarded forum technical member, listed these, but I am darned if I can find his post. It was well over a year ago, maybe 2 or more years ago. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 12, 2015 Share Posted January 12, 2015 Found it for you: http://www.mkivsupra.net/vbb/showthread.php?238522-2JZ-sensor-resistance! Link to comment Share on other sites More sharing options...
Calorus Posted January 12, 2015 Author Share Posted January 12, 2015 Found it for you: http://www.mkivsupra.net/vbb/showthread.php?238522-2JZ-sensor-resistance! Chris, you need to start a tab at your local for all the pints I owe you. One day I'll even up. Thank you! Link to comment Share on other sites More sharing options...
