Elmo Posted August 13, 2014 Share Posted August 13, 2014 My warning light's (ABS, oil pressure, oil level etc.) should illuminate when the ignition is turned on, then go out. I've just noticed that none of them are illuminating. The warning light's on the opposite side (seatbelt, door open etc.) are working fine. Any ideas why the lights might not be working, do they have their own fuse? Cheers! Link to comment Share on other sites More sharing options...
stevie_b Posted August 13, 2014 Share Posted August 13, 2014 They can suffer from a tiny crack in the PCB the lights are mounted onto. Repairable with a soldering iron if you've got good eyesight and a steady hand. Link to comment Share on other sites More sharing options...
Elmo Posted August 13, 2014 Author Share Posted August 13, 2014 They can suffer from a tiny crack in the PCB the lights are mounted onto. Repairable with a soldering iron if you've got good eyesight and a steady hand. Thanks for that. Would it be obvious to the untrained eye? Link to comment Share on other sites More sharing options...
straightsix Posted August 13, 2014 Share Posted August 13, 2014 Thanks for that. Would it be obvious to the untrained eye? possibly not but it's the 90% cause of failure. You could have a drive up to me in Stockport and I'll fix it for you if you like Link to comment Share on other sites More sharing options...
Elmo Posted August 13, 2014 Author Share Posted August 13, 2014 possibly not but it's the 90% cause of failure. You could have a drive up to me in Stockport and I'll fix it for you if you like Thanks very much for the offer, but your about 90 miles or so from me. I will have a look at the weekend, and might get back to you Link to comment Share on other sites More sharing options...
straightsix Posted August 13, 2014 Share Posted August 13, 2014 Thanks very much for the offer, but your about 90 miles or so from me. I will have a look at the weekend, and might get back to you Amazing. People drive over a hundred for pancakes but not to get a car fixed! Link to comment Share on other sites More sharing options...
Elmo Posted August 13, 2014 Author Share Posted August 13, 2014 Amazing. People drive over a hundred for pancakes but not to get a car fixed! I definitely wouldn't drive that far for pancakes, they're nice but not that nice! I'd prefer to check it out first, it could be as simple as the connector coming loose or something, if I draw a blank I'll get back to you. Thanks again. Link to comment Share on other sites More sharing options...
straightsix Posted August 13, 2014 Share Posted August 13, 2014 No problem. What usually happens is dry joints and fractures on the ribbon that joins the two circuit boards. A fine tip soldering iron should do the trick. Link to comment Share on other sites More sharing options...
Elmo Posted August 13, 2014 Author Share Posted August 13, 2014 Thanks for info, I will check it out. Link to comment Share on other sites More sharing options...
Elmo Posted August 13, 2014 Author Share Posted August 13, 2014 I've just had a fiddle. It looks like there is a loose wire on the connector. I unplugged it, then pushed it back in and turned the ignition on, hey presto the lights illuminated. I turned the ignition off, with a bit of pushing an wiggling got the cowel back in place, turned the ignition back on....no lights. Took it back out, and with the ignition on just touched the connector and the lights came back on. I managed to get the cowel back in place and screwed on without the lights going out, but I have a feeling that the next time I hit a pot hole or speed bump they'll probably go off again. I'll keep and eye on it, but if the problem persists I'm not sure how to fix it, new connector perhaps? Link to comment Share on other sites More sharing options...
mull1986 Posted August 13, 2014 Share Posted August 13, 2014 Mine was the same elmo, came on when wriggling the wires so I thought the same as you but like everyone else said above, you'll need to solder it. I done that and mines sorted. Cheapest thing to try first dude Link to comment Share on other sites More sharing options...
Elmo Posted August 13, 2014 Author Share Posted August 13, 2014 Mine was the same elmo, came on when wriggling the wires so I thought the same as you but like everyone else said above, you'll need to solder it. I done that and mines sorted. Cheapest thing to try first dude What did you solder, the wires going into the connector, or something on the PCB? Link to comment Share on other sites More sharing options...
ATB Posted August 13, 2014 Share Posted August 13, 2014 Exact same problem on my Supe. 1 minute with a soldering iron and everything was good again :-) Link to comment Share on other sites More sharing options...
mull1986 Posted August 14, 2014 Share Posted August 14, 2014 I soldered the "silver spikes" (haven't a clue what they're called to be honest). All of them and it worked a treat, good luck Link to comment Share on other sites More sharing options...
LOGIE Posted August 14, 2014 Share Posted August 14, 2014 Does anybody have pics of what exactly needs soldered? ive been through about 3 of these little light modules and even attempted to solder myself. unsuccessfully. Link to comment Share on other sites More sharing options...
dangerous brain Posted August 14, 2014 Share Posted August 14, 2014 (edited) There should be pictures on here. It's an old fault and I remember seeing pictures when I fixed my first one over ten years ago. It is very simple though. When you take the whole thing out of that top piece of dash you can see the spikey bits previously mentioned. Daub a blob of solder flux on them there spike ends, heat up a soldering iron and dab a blob of solder on it. Touch said blob on each spike in turn until the solder surrounding the spike shines up and you can see it flow. Remove iron from spike. Et voila you should have fixed it. http://mkiv.com/techarticles/trac_off_mil_odo/index.html Can't find the one on here but that tech article takes you through the whole thing Edited August 14, 2014 by dangerous brain (see edit history) Link to comment Share on other sites More sharing options...
LOGIE Posted August 15, 2014 Share Posted August 15, 2014 There should be pictures on here. It's an old fault and I remember seeing pictures when I fixed my first one over ten years ago. It is very simple though. When you take the whole thing out of that top piece of dash you can see the spikey bits previously mentioned. Daub a blob of solder flux on them there spike ends, heat up a soldering iron and dab a blob of solder on it. Touch said blob on each spike in turn until the solder surrounding the spike shines up and you can see it flow. Remove iron from spike. Et voila you should have fixed it. http://mkiv.com/techarticles/trac_off_mil_odo/index.html Can't find the one on here but that tech article takes you through the whole thing Thank you good sir Link to comment Share on other sites More sharing options...
Elmo Posted August 15, 2014 Author Share Posted August 15, 2014 There should be pictures on here. It's an old fault and I remember seeing pictures when I fixed my first one over ten years ago. It is very simple though. When you take the whole thing out of that top piece of dash you can see the spikey bits previously mentioned. Daub a blob of solder flux on them there spike ends, heat up a soldering iron and dab a blob of solder on it. Touch said blob on each spike in turn until the solder surrounding the spike shines up and you can see it flow. Remove iron from spike. Et voila you should have fixed it. http://mkiv.com/techarticles/trac_off_mil_odo/index.html Can't find the one on here but that tech article takes you through the whole thing Brilliant, thanks for the info Link to comment Share on other sites More sharing options...
