flyby Posted June 4, 2014 Share Posted June 4, 2014 hi, my MIL light (warring light) is on, but no fault codes in the ecu, where to start ? Link to comment Share on other sites More sharing options...
ScottC Posted June 4, 2014 Share Posted June 4, 2014 Check the brake fluid level Link to comment Share on other sites More sharing options...
Tommyd16 Posted June 4, 2014 Share Posted June 4, 2014 Engine managment light or big red triangle? If it's the engine managment light and u have no fault codes try using a decent bit of wire and not a paper clip (paper clip didn't work for me but wire did) otherwise if its just the big red triangle check coolant, brake levels etc as above ^ Link to comment Share on other sites More sharing options...
flyby Posted June 4, 2014 Author Share Posted June 4, 2014 big red triangle Link to comment Share on other sites More sharing options...
flyby Posted June 4, 2014 Author Share Posted June 4, 2014 check coolant: the TEMP working fine, the eletric fans also starting at 90 degress C. Can i check any other way ? brake levels : OK Link to comment Share on other sites More sharing options...
Tommyd16 Posted June 5, 2014 Share Posted June 5, 2014 All your doors, boot shut properly? Maybe a wire on a switch broken that closes when doors/boot are shut? Link to comment Share on other sites More sharing options...
Tommyd16 Posted June 5, 2014 Share Posted June 5, 2014 Do you have an active spoiler? That maybe kaput otherwise check for fault codes Link to comment Share on other sites More sharing options...
tomsupra1 Posted June 5, 2014 Share Posted June 5, 2014 Kept coming up for Brake Fluid for me, even when between the min/max line. Had to have it right by the max line. Link to comment Share on other sites More sharing options...
jim Posted June 5, 2014 Share Posted June 5, 2014 Brake fluid needs to be right up to the top, it's the most common reason for this happening. Link to comment Share on other sites More sharing options...
Scott Posted June 5, 2014 Share Posted June 5, 2014 This isn't the MIL light Chances are it's the brake fluid. Link to comment Share on other sites More sharing options...
