ATB Posted June 2, 2014 Share Posted June 2, 2014 Hello, I have a quick question... Does the mkiv have a rev limiter? A 100% stock tt 2jz-gte. Could you damage the engine in any way if you were to go to 7k or is there a limiter to prevent that? Might be a noob question, but coming from an S2000 it's a tad different. Link to comment Share on other sites More sharing options...
Wez Posted June 2, 2014 Share Posted June 2, 2014 Stock limit is around the 7200rpm mark for non-VVTI and 7500rpm for VVTI if I recall, when running the AEM ECU on a completely stock motor I increased this to 8000rpm for fun but wouldnt recommend it It did sound nice though.... Link to comment Share on other sites More sharing options...
ATB Posted June 2, 2014 Author Share Posted June 2, 2014 Thank you very much for the quick answer! Good to know the engine won't self destruct if you were unlucky to hit the limiter once Link to comment Share on other sites More sharing options...
Wez Posted June 2, 2014 Share Posted June 2, 2014 Good to know the engine won't self destruct if you were unlucky to hit the limiter once If it did mine would have died long long ago, as would I imagine most on here Link to comment Share on other sites More sharing options...
DaveR Posted June 2, 2014 Share Posted June 2, 2014 If it did mine would have died long long ago, as would I imagine most on here Yup, +1... Link to comment Share on other sites More sharing options...
Al Massey Posted June 2, 2014 Share Posted June 2, 2014 Limiter?????? I thought it was a target Link to comment Share on other sites More sharing options...
