jackies321 Posted April 1, 2014 Share Posted April 1, 2014 was planning on heading out today in my car as i have got in the car i had no power, i then got out the car to check if all the wires was secure on the battery, got back in lights on turned over and started the car, it then sounded a little funny so i turned the car off.... as i turned the car off and took the key out of the ignition its then tryed ticking over by itself ?????? i had to disconnect the battery to get the car to stop , tryed putting the battery on and it try's starting over as soon as the battery is on any idea's? Link to comment Share on other sites More sharing options...
Tommyd16 Posted April 1, 2014 Share Posted April 1, 2014 Short between positive and negative terminals on starter motor? Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 1, 2014 Share Posted April 1, 2014 Sounds like the solenoid in the starter is stuck or has shorted. See if you can give the starter solenoid body a few taps with something stout (don't smash it to pieces) and try to avoid hitting the connections. Then try reconnecting the battery again. Other than that it could be a faulty key switch but it's unlikely. Link to comment Share on other sites More sharing options...
Benjy Posted April 1, 2014 Share Posted April 1, 2014 The starter solenoid has to be stuck, give it a clout and try it again Link to comment Share on other sites More sharing options...
jackies321 Posted April 1, 2014 Author Share Posted April 1, 2014 thanks for the help guys was the solenoid much appreciated Link to comment Share on other sites More sharing options...
