j spec speedo in miles?
Guest gzaerojon
Guest gzaerojon
i just had my dash apart and took out my milometer, i noticed that you can see everything on the display that should light up, one of which is the "miles" light. so i guess my question is can it be converted to show in miles? has the display got the clever stuff in it, or is it just a display and the data is send from an ECU?
Just to add to this
My ODO Still shows km but clocks up in miles
however i was told that the actual "total mileage covered" will now clock up much slower with the odo now showing in miles, (although km still on screen)
i was told roughly add 6k miles on per year onto the total km figure on the total miles covered
If so
my car shows 102000 kms can this be converted to miles and corrected to the correct miles figure not 102000 miles?
This should then read correctly with both odo and total miles no longer in kms
hope this isn't to confusing
just another thought, if i do this will it count in miles?
See this link: http://homepage.ntlworld.com/peter.betts/supra/TechTips/odometer.htm
It's written by Pete Betts, who's very respected on here. I guess the method described by straightsix here is the same as the Peter Betts one, but I haven't examined them to confirm.
When you do the conversion, it'll count up in miles, but you'll either need to get the current value converted from kms to miles, or get a certificate like Class One said.
Guest gzaerojon
looks pretty good to me, thanks for that. anyone got a spare one kicking about for me to try, dont really wanna break mine till im sure
