Brake line dilemma
markssupra
In need of some advice on this, regarding being road legal and where to run the darn lines
I have 25 meters of Goodridge -3 stainless braided hose and stainless male fittings. After a lot of head scratching over the weekend on how/where to run the brake lines without bending the lines smaller than the minimum bend radius and interfering with suspension etc, I have come to the conclusion that I would rather replace the original lines with copper nickle lines instead and flare/bend as neccessary. All the male fittings I need for the braided hose should be M10x1 concave, but I cannot find anything with a swivel other than female fittings and then nothing to convert it to.
Opinions please on running all braided hose or replacing original steel hard lines with copper nickel. BTW my ABS pump is now behind the rear seat so makes it more awkward running 2 lines from the pump to the master cylinder.
Cheers John, What about running the braided lines under the car. The easiest route for the drivers side front to ABS pump in the boot is along the outside of the right side chassis rail, this avoids the 180° bend in the hose going through the inner wing. Would this be ok for a road car as I dont want it fail an MOT inspection.
as long as lines are run securely and not where they can be trapped and cut/pinched etc you will be fine, use p clips along the chassis rails and run it behind the heat shield under the master cylinder to protect from heat from downpipe.
