Fitting speed convertor
Tommyd16
Guest Roger NE
Aha - is that why the Main ECU requires a Speed Signal on the Pink wire - so it can LIMIT the top speed?
Originally I left this wire disconnected when fitting a 2JZ-GE in my Mk 3 . . . but kept getting an Engine Fault Light (and Fault Code said no speed signal)
So what speed is a JDM 2JZ-GE normally limited at?
I don't think Speed Limiting will be a problem, as the signal I have fed from the Mk3 dash is MUCH slower pulses . . . but it keeps the ECU from showing an error
(and apologies for hi-jacking your thread!)
Guest Roger NE
So presumably, if you guys fit a 8:5 downscaler to make the Speedometer read in MPH, and fed THAT signal to the main ECU too, it would just limit the top speed to 180 mph?
