jim Posted November 12, 2013 Share Posted November 12, 2013 I'm getting my split rims refurbed at the minute and am replacing the valves on the wheels while I'm at it. The wheels take an L shaped valve that can be tricky to get hold of, and can be expensive when you do find them. After a lot of searching I discovered that Camskill stock the valves I need, but they're around £5 each excl VAT, and for a set of 4 including delivery to Northern Ireland it's £35 I found the same valves on another UK site for £3 each and £3 delivery which works out at less than half the price Camskill wanted. So for the benefit of future searches, the link is http://www.wemoto.com/parts/picture/hl-500415_5/ These are the jobbies: L shaped 90 ninety degree tyre valve split rim Link to comment Share on other sites More sharing options...
Fitz Posted November 12, 2013 Share Posted November 12, 2013 I had replacement 'Tyre/Truck' Valves put on my old Works Equips pretty much the same as those above think it was about the same price, £2-3 per valve Link to comment Share on other sites More sharing options...
