Guest looneytoones Posted January 4, 2014 Share Posted January 4, 2014 Shouldnt you only drive around 50 miles with tyre sealant? I've got the understanding that the tyres become unpredictable while sharp cornering and high speeds..... its the wheel that is the problem not the tyres when the tyre is removed from the wheel around the bead area it should be clean and smooth, but if its lumpy and looks crusty(like rust) then thats the problem Link to comment Share on other sites More sharing options...
Guest looneytoones Posted January 4, 2014 Share Posted January 4, 2014 Shouldnt you only drive around 50 miles with tyre sealant? I've got the understanding that the tyres become unpredictable while sharp cornering and high speeds..... you are rite tyre sealent is like pouring a kettle full of water in the tyre, it will throw the wheel out of balance and also cause un wnated handling issues Link to comment Share on other sites More sharing options...
