Johnny176 Posted September 7, 2013 Share Posted September 7, 2013 Evening Guys, There's a good few threads on ignition timing but I couldn't find any which mentioned an easy enough way to actually do it. Can anyone point me in the right direction for a quick how to? I know how to use the timing gun but I'm unsure of the best way to go about it on the supra engine. If there is a difference between the 2, I have the 2JZ GTE engine Thanks Link to comment Share on other sites More sharing options...
Swampy442 Posted September 8, 2013 Share Posted September 8, 2013 (edited) First question is why do you need to do it? It cant be adjusted on the GTE. I havent got a car handy to get pics, but on top of the plug that connects to the ignitor unit theres a flap that can be opened. Inside this plug theres a load of wires, but also 1 wire thats longer than the rest, clip your timing lead onto that and away you go. I know on other Toyota engines if you bridge the ports TE and E1 in the diagnostic port, this obviously puts in in diagnostic mode, but also sets the timing to an arbitrary point, like 10 degrees btdc or something. Edited September 8, 2013 by Swampy442 (see edit history) Link to comment Share on other sites More sharing options...
Guest Roger NE Posted September 8, 2013 Share Posted September 8, 2013 Yes you need to link the two pins on the Diagnostic Port to stop any Advance/Retard on the ignition, so you can set it at the "Static Timing" point. And clip your Timing Light's sensor onto plug number 1 (at the front of the engine) Link to comment Share on other sites More sharing options...
Swampy442 Posted September 8, 2013 Share Posted September 8, 2013 Its a TT Link to comment Share on other sites More sharing options...
Johnny176 Posted September 8, 2013 Author Share Posted September 8, 2013 Thanks Swampy, I have an aftermarket ECU and I just wanted to see if the engines ignition timing was the same as what the ECU thinks it is Link to comment Share on other sites More sharing options...
