2soops Posted July 16, 2013 Share Posted July 16, 2013 Hi all, I need to get hold of the four little plastic wheel arch fittings the bolts screw into that are used to hold the back of the skirts and the same ones for the spats. I have checked with Steve Manley but he couldn't determine which ones they are as the images on Toyotas system are too blurry. Any help with a clearer picture showing part numbers or just the numbers themselves would be great as I don't want to order the wrong clips then have to return them. Thanks Al Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 16, 2013 Share Posted July 16, 2013 http://www.toyodiy.com/parts/diag_2DIcgp.png Is this image visible to you as sometimes they aren't. If it is visible is it anything that is of any use to you as I'm not quite sure what it is you are searching for. Link to comment Share on other sites More sharing options...
2soops Posted July 16, 2013 Author Share Posted July 16, 2013 No mate, not visible. The bits I'm after are the small plastic plugs that push through the holes in the lip on the rear wheel arch, then the skirts and spats are fixed to them with screws Link to comment Share on other sites More sharing options...
Abz Posted July 16, 2013 Share Posted July 16, 2013 Have you tried speaking to Keron on the forum to see if he has these fittings? Link to comment Share on other sites More sharing options...
2soops Posted July 16, 2013 Author Share Posted July 16, 2013 Not yet but theyre only small bits of plastic about the size of a pen lid and are hard to get out without breaking them. It's no problem getting new ones, just need the correct part numbers Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 16, 2013 Share Posted July 16, 2013 How about now? Link to comment Share on other sites More sharing options...
2soops Posted July 16, 2013 Author Share Posted July 16, 2013 Yes mate, your a legend, thankyou. I need the plugs 90189-04219 x6, 3 for each rear section of the arches. The diagram dosent show the front of the rear arch lip plugs for the skirt rear fixings though, theres only 2 there instead of 3 and they are round holes not square like the back ones. Dont suppose you can find a picture of those too Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 17, 2013 Share Posted July 17, 2013 How about this one? Link to comment Share on other sites More sharing options...
2soops Posted July 17, 2013 Author Share Posted July 17, 2013 You sir are an absolute legend, that's exactly the info I need. Thank you very much for taking the time to sort those for me, I owe you a pint for sure, Al Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 17, 2013 Share Posted July 17, 2013 Happy to help Al. Link to comment Share on other sites More sharing options...
