The Hornet Posted August 18, 2005 Share Posted August 18, 2005 Have 2 sets of Genuine Toyota Rear pads sat here which the garage I took it to, to have them fitted said they didnt fit? Toyota code: 04466-14040 I have read another old thread on here about the toyota code: 04466-30030 Can any one actually confirm which ones I need as I have a 1993 J spec with J spec brakes and the rear pads are absolutely knackered and the 04466-14040 pads dont fit (or as I was told by the garage) ASAP plz, cheers Hornet Link to comment Share on other sites More sharing options...
colsoop Posted August 18, 2005 Share Posted August 18, 2005 Have a look at ther attached picture: The part number you quoted first is for the bigger calipers. Link to comment Share on other sites More sharing options...
The Hornet Posted August 18, 2005 Author Share Posted August 18, 2005 Thanks for the quick reply matey, but the garage only looked at them without removing the wheels etc and said that the 04466-14040 pads that I have 2 sets of sat here are no where near the size of the ones on the car? edit: They said that the ones on the car are closer to the same size as the fronts? But I know they are J spec as the front ones are! Link to comment Share on other sites More sharing options...
colsoop Posted August 18, 2005 Share Posted August 18, 2005 So did they say that the ones you have got (04466-14040) Are bigger or smaller than the pads that are on their at the moment ? Did they actually physically compare the two? Link to comment Share on other sites More sharing options...
The Hornet Posted August 18, 2005 Author Share Posted August 18, 2005 They said the ones I have, the: 04466-14040 are smaller than the ones on the car or should i say Shorter in width. And no they didnt take them off the car to look, which is pissing me off Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 18, 2005 Share Posted August 18, 2005 As I said on the phone, sounds like you have UK rear calipers on it, ask them to say if they are one piston, sliding calipers, or 2 piston, fixed. The latter are UK ones. Link to comment Share on other sites More sharing options...
The Hornet Posted August 18, 2005 Author Share Posted August 18, 2005 Hi Chris, thanks for info and help on phone, now that I have got home and had chance to look at them I found that: The rear brakes are not UK spec as I found some pictures of the UK ones. They are J spec ones, or look like J spec ones, however the pads are much wider and the height is less than the standard J spec ones. Wierd really... I will take their measurements at weekend and provide the relevent information. I also found out that there are 2 different types available for earlier 1993-1994 J Spec's so have a set of the others on order to see.. Once I have this problem sorted out I will take pictures and provide order codes for future reference. Bloody nightmare really as they rear pads are in a real low state and squeeling so I cant even drive it or risk wrecking the discs Link to comment Share on other sites More sharing options...
