what other parts do I need to install series 2 indicator/park lights ?
Guest Malachi
Guest Malachi
hey guys , I just got my indicator lights image(1).jpg I dont know how to identify the parts I have and the parts I still need from
http://www.supraforums.com/forum/showthread.php?375951-HOW-TO-Install-Clear-Front-Turn-Signals
http://www.mvpmotorsports.com/merchant/tech/turnsig/tsinstall.htm
can some one help me out on what parts I still need to complete this installation with park light working as well
cheers
You will either need to fabricate a wiring harness for the right hand side one in the pic or you could buy another harness (same as the one on the left). If you do buy another harness (part number 81515-14390) you will need to modify the holes in the back of the indicators so the bulb holders will fit - if you remove the bulb holders and swap them over now you'll see what I mean.
If you are fitting to a prefacelift Supra they are not a straight swap, you'll need to splice the wiring in or swap the plugs over, there is an install guide here: http://www.mkivsupra.net/vbb/showthread.php?31633-How-To-Fit-facelift-front-indicators&highlight=Indicators
Install guide here: http://www.mkivsupra.net/vbb/showthread.php?31633-How-To-Fit-facelift-front-indicators&highlight=Indicators
Your knowledge knows no ends. :salute:
