PC help
tbourner
Thanks westlife you joker!! :p I meant drivers specific for the TV, as the ATI drivers are just using the default drivers for the screen.
Jay, it's an LCD TV so it doesn't have 'scan lines' as such, and can support 100Hz. Just would've thought the graphics card drivers would need to know what it is in order to give out more than the basic info (which they do to protect cheap nasty CRT monitors that can't handle it).
Try the omega drivers, on google just search for 'ati omega'... however I doubt you will get a good picture on the tv, after all the res is a lot lower, and the refresh rate..
Does the TV support a 15pin VGA connector directly?? also note that LCD's are fuzzy if they aren't running at native resolution due to the way it does pixel interpolation..
Gav
Yeah it's got a 15 pin din cable on it, and it's supposed to be designed with graphics card use in mind, but it belongs to a bloke who works in cash converters so I doubt he managed to get hold of any official documentation or drivers with it!!! :rolleyes: :taped: :angrymod:
