Project 200sx s14a :)
Guest 200sxray
Guest 200sxray
I thought i would put up my build thread so far of the 200sx, as we are all petrol heads and like to see some insperation for modifications, i am new to the site but hope you all follow my thread i will be keeping it as upto date as possible
And so it begins, i went and collected my new car a couple of days ago, i completed the PX deal with my Audi and away home i drove from Leeds
Now the current spec
Block:
ACL main bearings
ACL con rod bearings
ACL thrust washers
ARP main bolts
ARP con rod bolts
ARP head studs
HKS 1.2mm metal head gasket
New GTI piston rings
Head:
Skimmed
Cleaned
Pressure tested
Valves cleaned, lapped and new VSS's
Engine misc...
New gaskets and seals all round!
Custom blue painted rocker cover
Blue silicone coolant hoses
Stage 4 paddle clutch from compitition clutches
Induction:
Apexi dual cone filter
Apex Type 2 FMIC and piping
Turbo/manifold
Stainless steel manifold ( unsure of make)
New Nissan manifold to head gaskets
New turbo to manifold gaskets
Studs welded to manifold and lock washer and nuts to stop the turbo coming loose/blowing
Blitz bov
Fuelling...
Walbro fuel pump
Stock injectors, flow checked
Exhaust...
Japspeed Stainless steel 3" exhaust elbow (s14a)
Stainless steel decat (345mm)
Apex cat back exhaust ( new)
Suspension/ brakes / steering wheels
Stock shocks with 30mm apex lowering springs
Apex poly steering rack bushes
R33 skyline GTST front brakes with new ebc discs and pads
Front calipers refurbed
Driftworks braided brake lines all round
350z nismo forged 18" alloys
Electronics
Blitz Uras SBC
Sony head unit
Exterior
Clear front indicators ( genuine Nissan)
Clear side repeaters
Touring side skirts
Led side lights
HID dip beam
she came with a horsham dev stage 1a chip which is in now, once the boost is set up she should be running 285bhp and 300fb.
Then i bought a brand new Apexi Boost gauge and decided to mount it in the centre of my dash :)
My Vision
Then the parts went away for flocking
Finaly got the parts fitted up :)
Guest 200sxray
Then i had an issue with Boost creep, the wastegate wasnt flowing enough gasses so off came the turbo and out came the grinding stones...
Before
After
and the turboless engine bay pic :)
The turbo now holds a good steady 1bar all the way to 6k
- - - Updated - - -
Things were a tad loud so i popped a silenced Decat on and she has now been noise tested at 95DB at 4k
Next thing on the list was to solve the slight fuel leak.... off came the Plenum and fuel rail to find the injector seals to be shot.. and a couple of the Pintles broken.
30pounds of seals and pintles later and she was back running fine :)
so after all of that i decided to treat the car to the following..
* Aero Blades
* Import front Number plate
* Silvia front lightening Badge
* Set of new Wheels 5spoke Bronze wheels.
* Tien Super street Coilovers
* DB Power 345mm Big Brake Kit
* LED rear number plate lights :) ( most important)
and a trip to Cadwell park for her first track day!! :) i need to get some clean upto date pics of the new modifications but i have some from the track :)
And that now brings us bang up to date.. apart from a few choice things that i will grab some pictures of tomorrow
thoughts and comments guys :)
Guest 200sxray
cheers mate, i hope i have done all your hard work proud!!
a few more pictures to come and updates will try and get some pictures tomorrow :)
  • 3 weeks later...
Guest 200sxray
right guys, waiting on the car getting out the body shop its been 3 and a bit weeks now :( missing her.. but i have bought some goodies in the mean time..
Including a Recaro SR3 for the drivers seat
OMP Steering wheel and HUB
Roof Spoiler / Visor from america (Aunts over their at the min)
http://www.ebay.co.uk/itm/230901150108?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
And the Bargin Recaro :)
http://www.ebay.co.uk/itm/261147171230?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
i promise i will do a shoot when she comes out the body shop, she is in for
Front and rear tinted lights
Front end respray
Rear number plate garnish spray.
Cheers Andy
  • 2 weeks later...
