BPU TT to run turbos in parallel all of a sudden went back to sequential?
p3te
ive had my bpu tt set up and mapped to run turbos and parallel for a few year now but just been out and its running in sequential again? how could it start running like this again when i haven't re connected the hoses to run in sequential, ill check it out in the day to see if there's anything like hoses popped off but not sure how it could go back like that without re connecting the vac hoses up
Just checked that article it looks a bit of a faf on wiring the actuators open and it says not to run like this for more than a few days, is this the way most people do it? Strange how its just went back all of a sudden with the hoses still disconnected,
Bit baffled with this now I've checked a few sites and the vac lines are connected right but still it runs the same, when ryan mapped it he put it to ttc as one of the vsv were faulty and the 2nd turbo wasn't spooling, its been running fine with both turbos working best part of 2 year now its went back to sequential, the sound has went back to how it was and the turbos spooling early again as if it was back to running sequential, I don't know how tho with the vac lines connected the way they are
Running ttc should the exhaust valve be open all the time? Looking at this now its not moving at all not even when I rev it, it was rattling quite loud a few weeks ago if this has failed that would explain why turbo 2 isn't working and I'm not getting the ttc sound is that right? Also I read these can be bought but part of it is fixed to the turbo and if it needs changing the turbo does as well?
Everytime I've done a TTC I've used 1 way valves. There isn't any in there at all.
That long thin pipe in the last pic that's just hanging should go to the exhaust bypass valve with a 1 way valve in it so when it opens the 1 way valve holds pressure and keeps it open.
How could it be fine for nearly 2 year tho and just stop? Should the exhaust valve be moving on the vid? It use to I think when it was rattling
- - - Updated - - -
I'd have left it plummed as it should be in sequential but put a 1 way valve between the exhaust gas bypass valve and the VSV and a 1 way valve between the top turbo actuator and VSV. It should work as it is but I've a feeling you've plummed in the exhaust bypass wrong when you changed your pipework.
