paul21uk Posted October 4, 2012 Share Posted October 4, 2012 alright guys ive just about finished the rebuild of my 1jz its replacing my 2jz na. What throttle cable will be a excellent fit as ive read up and it says the soarer one is way to long but the 2jz is inches to short any help would be fab as its being put into the car this weekend cheers Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 4, 2012 Share Posted October 4, 2012 You will get out of trouble with a 2JZ-GTE accelerator cable. If you can find one. They're usually sold as part of a TT transplant so don't come up very often as a seperate item. They are available new obviously but where is the fun in that! There may be several other cables from the Toyota stable that may suit but I haven't seen any mentioned that do the job like the TT cable does. You will also need the T.T. P.S. reservoir and some of its plumbing if you haven't already sourced it as the NA set-up won't fit. (The pump will but not the NA reservoir) Link to comment Share on other sites More sharing options...
David P Posted October 4, 2012 Share Posted October 4, 2012 Speedograph Ritchfield at Nottingham will make you up a cable for around £30, just send them your old N/A cable and tell them the length you need it to be. Link to comment Share on other sites More sharing options...
paul21uk Posted October 4, 2012 Author Share Posted October 4, 2012 cheers guys just purchased the complete set assembly cable th works for 48 quid from toyota for 2jz gte and PEDROSIXFOUR already have all the plumbing and p.s from a soarer mate thanks kinda hoping thats nearly everything Link to comment Share on other sites More sharing options...
