monsween Posted August 12, 2012 Share Posted August 12, 2012 Just a double check i'm onto the right thing here, what are the HID bulbs i'm looking for? Facelift headlights. 9005, HB3 fitments? Cheers Kieran Link to comment Share on other sites More sharing options...
monsween Posted August 14, 2012 Author Share Posted August 14, 2012 Bump Link to comment Share on other sites More sharing options...
st3ven1 Posted August 14, 2012 Share Posted August 14, 2012 Yup 9005/HB3 for both high and low beams. Link to comment Share on other sites More sharing options...
drift_bear Posted August 14, 2012 Share Posted August 14, 2012 Think I might have an unused set lying around here mate, will have a look if your interested? Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted August 15, 2012 Share Posted August 15, 2012 Lots of lube on them orings they my be to big. Link to comment Share on other sites More sharing options...
supra78669 Posted August 15, 2012 Share Posted August 15, 2012 hi mate, you can use the HB3 bulbs however, you will have to trim down the 3 "spoke like" bits in order to get them to fit. I shortened mine with a stanley knife and they fit good. Bit fiddly but when you try fitting them it will make perfect sense as to what areas you will need to trim. Link to comment Share on other sites More sharing options...
