mikeyh Posted August 9, 2005 Share Posted August 9, 2005 hi guys just about to take the sump off of my gearbox to reseal as she is beginning to weep a little,can anyone tell me how much transmission fluid i will need to refill the box. without emptying the torque converter? Quote Link to comment Share on other sites More sharing options...
Shovels Posted August 10, 2005 Share Posted August 10, 2005 I had mine done at Stertegarage and they apparently put just over 3 litres in. There's has been quite a lot of stuff on the type of oil you should use. Alex is your man to talk to about this, but basically, the stuff from Toyota - V160 gearbox oil is what you want. I had mine changed at the last service and have noticed smoother gear changes and much less heat being transmitted through to the gearstick. Quote Link to comment Share on other sites More sharing options...
JohnA Posted August 10, 2005 Share Posted August 10, 2005 it's over 8litres mate in total, but it's difficult to change more than half of that in one go. Possible though, if you know how. Just take off the little sump and clear the filter screen as well. That should allow you to replenish more than 3 litres of the stuff. Make sure you check the level in the correct way, and only use Toyota typeIV oil. Quote Link to comment Share on other sites More sharing options...
Shovels Posted August 10, 2005 Share Posted August 10, 2005 8 Litres! Does that mean that the garage didn't do the job properly then!? Quote Link to comment Share on other sites More sharing options...
JohnA Posted August 10, 2005 Share Posted August 10, 2005 Not at all. Toyota only recommend changes of 1 odd litre, by draining that little sump (which is not designed to drain completely either!) However, make sure that they used the correct fluid, typeIV. Anything else is not acceptable. Quote Link to comment Share on other sites More sharing options...
garethr Posted August 10, 2005 Share Posted August 10, 2005 8 Litres! Does that mean that the garage didn't do the job properly then!? Mikey and John are discussing the autobox rather than the 6-speed. Quote Link to comment Share on other sites More sharing options...
Shovels Posted August 10, 2005 Share Posted August 10, 2005 Mikey and John are discussing the autobox rather than the 6-speed. Ahh OK then, had me worried for a moment! Quote Link to comment Share on other sites More sharing options...
JohnA Posted August 10, 2005 Share Posted August 10, 2005 yes ofcourse, I thought the original reference to the torque converter covered that. Quote Link to comment Share on other sites More sharing options...
