HELP: Rear upper suspension arm rubber mounting.
tony1
Took my 94 UK spec for an MOT and passed but had an advisory for rear upper suspension are rubber mounting deteriorated on both sides.
I'm trying to find out if you can get new ones on there own and if so does anyone know the genuine Toyota part number for them?
It's either new complete arms from Toyota or you buy polybushes and get the old bushes
removed and the polybushes fitted to your upper arms.
Rear upper arms from Toyota are very expensive and approx £360 each + vat
Tony,
Poly bushes readily available.
Paul has them for sale amongst many others.
http://whifbitzperformancetuning.co.uk/toyota-supra-suspension-parts-poly-bushes-c-38_43_665_720.html
To be honest it is money well spent on any Supra now a days if you re-bush the whole suspension (front and back). Better spent on this than a body kit TBH or some tarty add on. Cost will depend on whether you do it yourself or pay someone and whether you re-bush (if your ball joints are ok) or if you have to buy OE replacements. Also add in the cost of a suspension set up by a professional suspension team rather than kwik fit.
