luisito-awo Posted April 29, 2012 Share Posted April 29, 2012 hi guys is the gs400 rear end the same compared to an supra natural aspirated rear and? if so or not what are the difference? is it harder than the n/a one or so? because my ring and pinion of my n/a diff has broken and i have someone here with an gs400 diff. so i want to know that so i can buy this one for my supra or not thx Link to comment Share on other sites More sharing options...
Nic Posted April 29, 2012 Share Posted April 29, 2012 The diffs should be interchangeable but how much needs swapping over will depend on which diff each car is fitted with. The axle code on the VIN plate of each car will tell you which diff is fitted, post up the codes here. Register HERE and input the details for the cars, then go to the diff/final drive section this should tell you what final drive gearing is fitted to each. Link to comment Share on other sites More sharing options...
