kniff_666 Posted March 23, 2012 Share Posted March 23, 2012 (edited) Hello guys, Thinking of changing the positionand style of my scabby old fog light because it looks completely wrong. from the picture below its not clear but it does look rubbish (circled in red) I am thinking of replacing it with a flush fit one in the middle of the bumper under the number plate (red cirlce) or either side of the number plate (blue circle). thinking of using this item off ebay: Has anyone done this before? I am a little concerned about a couple of things: 1. I think that cutting a hole in this point of the bumper will weaken it (structurally risking the curves of it) 2. if it looks rubbish then i will have a hole in the bumper 3. access behind the bumper to allow room for the light and to fit without taking the bumper off please let me know your thoughts Edited March 23, 2012 by kniff_666 (see edit history) Link to comment Share on other sites More sharing options...
jonc Posted March 23, 2012 Share Posted March 23, 2012 (edited) Take off the naff one and wire into the rear light cluster like most of us have done. You can either go into one of the brake lights or reversing light. Just search rear fog light and the wiring diagrams will be there. Most of the hard work is done with yours because the wiring from the switch has already been done Just found this thread which will help http://www.mkivsupra.net/vbb/showthread.php?80479-Fog-Light-Conversions-for-beginners&highlight=rear+fog+light+wiring Edited March 23, 2012 by jonc (see edit history) Link to comment Share on other sites More sharing options...
SteveR Posted March 23, 2012 Share Posted March 23, 2012 Ditch the nasty add-ons completely and do the fog light mod. Link to comment Share on other sites More sharing options...
ellis Posted March 23, 2012 Share Posted March 23, 2012 Take off the naff one and wire into the rear light cluster like most of us have done. You can either go into one of the brake lights or reversing light. Just search rear fog light and the wiring diagrams will be there. Most of the hard work is done with your because the wiring from the switch has already been done Link to comment Share on other sites More sharing options...
kniff_666 Posted March 23, 2012 Author Share Posted March 23, 2012 Thanks for the help guys. How long will it take roughly and do i need to be a master electrician to do it? I am more keen on the mechanical aspect of working on cars than the electrics. Link to comment Share on other sites More sharing options...
jonc Posted March 23, 2012 Share Posted March 23, 2012 I have just added a link to post telling you all you need to know Link to comment Share on other sites More sharing options...
ellis Posted March 23, 2012 Share Posted March 23, 2012 I have just added a link to post telling you all you need to know This forum is so Moneysupermarket! Link to comment Share on other sites More sharing options...
SteveR Posted March 23, 2012 Share Posted March 23, 2012 Thanks for the help guys. How long will it take roughly and do i need to be a master electrician to do it? I am more keen on the mechanical aspect of working on cars than the electrics. between 1-2 hours for a first timer: look for the full instructions (they're on here somewhere!) but use your existing fog light wiring to activate the relay (saves you running a whole new set of cabling, as jonc has said) Link to comment Share on other sites More sharing options...
Colin-mkiv Posted March 23, 2012 Share Posted March 23, 2012 I need someone to do this mod for me....I was simply going to put a red bulb in one of my reverse lights and wire it up to the foglight switch. Link to comment Share on other sites More sharing options...
SteveR Posted March 23, 2012 Share Posted March 23, 2012 I need someone to do this mod for me....I was simply going to put a red bulb in one of my reverse lights and wire it up to the foglight switch. That is ok for the MOT, too, but it's a bit shabby TBH. That's how mine is wired up (was when I bought it) but I'm going to change it back to 4 brake/rear lights the first chance I get. Link to comment Share on other sites More sharing options...
Colin-mkiv Posted March 23, 2012 Share Posted March 23, 2012 Yeah, I know its the simplest means to an end....But I hate doing wiring. I'm just not onfident with it. I can do absolutely anything else on the main oily bits but wiring is my achiles heel. Link to comment Share on other sites More sharing options...
SteveR Posted March 23, 2012 Share Posted March 23, 2012 Yeah, I know its the simplest means to an end....But I hate doing wiring. I'm just not onfident with it. I can do absolutely anything else on the main oily bits but wiring is my achiles heel. Think of it as plumbing, for electrons! Link to comment Share on other sites More sharing options...
heckler Posted March 23, 2012 Share Posted March 23, 2012 I make a small circuit that can converts one pair of brake lights into fog lights... Nice and simple Link to comment Share on other sites More sharing options...
Colin-mkiv Posted March 23, 2012 Share Posted March 23, 2012 Think of it as plumbing, for electrons! .....did I mention, I'm naff at plumbing too....the elecTrons would keep escaping and there wouldn't be enough pressure left to light the bulbs! Link to comment Share on other sites More sharing options...
garethr Posted March 23, 2012 Share Posted March 23, 2012 I make a small circuit that can converts one pair of brake lights into fog lights... Nice and simple So you do! http://www.mkivsupra.net/vbb/showthread.php?253183-Rear-Fog-light-PCB Missed that thread. Any left? Link to comment Share on other sites More sharing options...
heckler Posted March 23, 2012 Share Posted March 23, 2012 So you do! http://www.mkivsupra.net/vbb/showthread.php?253183-Rear-Fog-light-PCB Missed that thread. Any left? That's the thread I was trying to find! Link to comment Share on other sites More sharing options...
