djg99 Posted March 20, 2012 Share Posted March 20, 2012 As im installing some new gauges into the car and have all the dash out i thought id have a look at my delimiter and speed converter as every so often my speedo stops working. used to search button as well as the guide to see what i should be checking, but now i cant find them!!! the whole dash is out including speed cluster, radio, and i cant find them anywhere, even checked near the gearbox lever and ECU! now i no the car has a delimiter as ive been over erm cough cough 120mph on a private road!!! anyone help???? Link to comment Share on other sites More sharing options...
stevie_b Posted March 20, 2012 Share Posted March 20, 2012 How do you know you've been over 120 leptons? If the speedo said (say) 125 leptons then chances are you were going less than 120. The converter/delimiter is probably a small (no bigger than a small matchbox) device, maybe not tied down to anything, with a few wires coming out of it. There's a diagram of how to connect a Thor converter on here (a few of my posts about code 42 link to it), and from that you should be able to see what wire is the speedo's speed input signal. If you have a converter, it must be spliced into that wire somewhere. Link to comment Share on other sites More sharing options...
