Best fuel computer
Toms Supra
i want to get some bigger injectors, probably vortex`s plug and play jobbies, whats best to run them. I was thinking of getting apexi S-AFC II would this be ok? Does this require mapping? Greddy emanage does doesnt it?? Im not sure whats best? Im only running hybrids atm but plan to go single soon just want to sort out the little jobs first. :looney:
Both Alex! lol Im on a tight budget! Anything will do just to run them!
Ok best place to get emanage then if I got it with everything needed? And how big a job is it to fit? i dont know who could map it round here im down in Dorset! :( Everyone seems up north! lol
It all depends on what you are adding...
If it is initially only injectors then it is a fairly easy job, as easy as installing the SAFC....the emanage intercepts pretty much the same wires...
in fact in some cases, you can even buy a fields harness with all the wires install, but they are a little pricey...
Gav
Mine is in and working, I'm still having the subtle issue of my MAF sensor hitting the end of its resolution, however below that it is running sweetly...
The target AF seems to be working well, just need to solve the other prob...
Gav
