blitz supra Posted July 28, 2005 Share Posted July 28, 2005 Hi Would anyone out there have an Induction kit for a 95 Non Turbo Supra Ideally I just need the connecting pipe as I have a brand new Blitz cone off my FTO I just sold, Or does anyone know the pipe diameter, Looks like it would be easy to make a kit if it was a 75mm/ 3in pipe I could just use plastic tubing of correct diameter or source an alloy tube I can put the switch back in it easy enough by ordering another grommet from Toyota Cheers Andy blitz Supra "If you can't go sideways go home" Quote Link to comment Share on other sites More sharing options...
legendswraith Posted August 6, 2005 Share Posted August 6, 2005 i am assuming that the supra lump is the 2jz-ge the same as in my lex if so the pipe dia on my induction kit is 88mm (3.5in) only problems i had was i had to use silicone hoses to go onto my mas sensor body but i don't know if its the same type on the supra Quote Link to comment Share on other sites More sharing options...
