Guest paul bell Posted January 10, 2012 Share Posted January 10, 2012 Just fiited some led bulbs behind the speedo they work fine but now the speedo and rev counter isnt working, and for some strange reason the car is reving by itself. Has anyone got anyideas Link to comment Share on other sites More sharing options...
Purity14 Posted January 10, 2012 Share Posted January 10, 2012 Did you plug all the connections back in Link to comment Share on other sites More sharing options...
Scott Posted January 10, 2012 Share Posted January 10, 2012 Sounds like you have plugged the wrong connector in. The back of mine has 3 plugs but only 2 are used, the 3rd one I'm guessing is for auto cars? The clocks I have has a plug hole but there is no circuit going to it. If you put the wrong plug in or if you put the correct plug in the blank plug hole you will get issues like you mention. Link to comment Share on other sites More sharing options...
Purity14 Posted January 10, 2012 Share Posted January 10, 2012 True Scott, also some of the connections are awkward to get in - so have another check, take the dials out and try again Link to comment Share on other sites More sharing options...
Noz Posted January 10, 2012 Share Posted January 10, 2012 Check you haven't pulled a wire our by mistake on one of the connectors. Link to comment Share on other sites More sharing options...
Guest paul bell Posted January 10, 2012 Share Posted January 10, 2012 I've sorted it thanks lads it was 1 of the fuses in the footwell. Link to comment Share on other sites More sharing options...
