Heat wrap, how much? Should I wet it?
Scott
 Share
Do you know what that tool is called? I can't find anything :shrug:
Look for a "cable tie tensioner". There are quite a few different designs, but it's essentially the same tool as is used to tie the stainless straps to pallets - so most industrial places will use them.
Late as usual :p
I bought these...
http://www.ebay.co.uk/itm/180643596450?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Doesn't mention any tooling to fit them?
lol what a bargain price.. i payed 10 times that for mine an the problem i had with mine. there is a little stealball inside the tieclamp and when you tighten they tend to back off just a millimeter or fractions of a millimeter and then they aren't verry tight anymore. ill see if i can find what i used. and its a lot easier to get a tight fitting with since you just take a plier and turn.
somthing like this just abit thicker
http://www.ebay.co.uk/itm/20m-Stainless-Steel-316L-wire-HHO-fuel-saver-Water4Gas-/110455866502?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19b7aec486
Edited by Hellstrom (see edit history)
Yeah that's what we use in work. I'll see if I can 'borrow' some :sly:
 Share
