mattysupra Posted August 15, 2011 Share Posted August 15, 2011 Right then, im currently building a high spec engine. The car is a Auto at the moment and soon to become a manual. But on my spec list im going to be using a after market plenum and throttle body. THE QUESTION..... how does the Auto react to a after-market plenum? I ask as if i remember correct the AUTO shuts the throttle off on gear changes as with a after market plenum it wont? Is this a issue? Link to comment Share on other sites More sharing options...
Ian C Posted August 15, 2011 Share Posted August 15, 2011 If it's converted to a manual gearbox, why is this an issue? If it's a high spec engine won't you be using a different ECU anyway, so the stock autobox control again becomes a non issue Link to comment Share on other sites More sharing options...
mattysupra Posted August 16, 2011 Author Share Posted August 16, 2011 If it's converted to a manual gearbox, why is this an issue? If it's a high spec engine won't you be using a different ECU anyway, so the stock autobox control again becomes a non issue Its going to be used as a Auto untill i find a manual box at the right money. And yes it will be using a HKS FCON Pro 3.24 ecu. But this dosent control the gearbox? my question is tho, does the throttle need to be released on gear change? As im using a different throttle body etc? Link to comment Share on other sites More sharing options...
Ian C Posted August 16, 2011 Share Posted August 16, 2011 You should be able to lower the power briefly during gearshifts by pulling ignition timing instead. The EMU can do it so I imagine other ECUs can as well. Dude would know more, he's got loads of experience with autoboxes Link to comment Share on other sites More sharing options...
