k9l3 Posted August 10, 2011 Share Posted August 10, 2011 I been told my front brakes have been changed to UK spec so what size discs would I need please. anyone? also what pads would I need? Link to comment Share on other sites More sharing options...
heckler Posted August 10, 2011 Share Posted August 10, 2011 I been told my front brakes have been changed to UK spec so what size discs would I need please. anyone? also what pads would I need? OEM UK spec disks and Chris Wilson fast road pads (trader on the forum) Link to comment Share on other sites More sharing options...
k9l3 Posted August 10, 2011 Author Share Posted August 10, 2011 OEM UK spec disks and Chris Wilson fast road pads (trader on the forum) the thing is its something I might change and if I do just want a cheap replacement as could be selling the car. http://www.ebay.co.uk/itm/SUPRA-TURBO-323mm-FR-BLACK-DRILLED-GROOVED-BRAKE-DISCS-/320532538086?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aa13a62e6 would they fit and be ok. I have had ebay discs before and was fine Link to comment Share on other sites More sharing options...
heckler Posted August 10, 2011 Share Posted August 10, 2011 the thing is its something I might change and if I do just want a cheap replacement as could be selling the car. http://www.ebay.co.uk/itm/SUPRA-TURBO-323mm-FR-BLACK-DRILLED-GROOVED-BRAKE-DISCS-/320532538086?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aa13a62e6 would they fit and be ok. I have had ebay discs before and was fine personally, i wouldn't touch them with a barge pole... the supra is a big heavy car, cheap cross drilled/grooved disks have a habbit of cracking due to the manufacture process. I put tyres and brakes in the same basket - one area not to "go cheap" in, but like I said its just my oppinion. What if you dont sell Link to comment Share on other sites More sharing options...
Josh Posted August 10, 2011 Share Posted August 10, 2011 If you're changing the brakes anyway, do the discs and pads need changing now? Are they really low? I agree with the above, don't buy cheap Link to comment Share on other sites More sharing options...
k9l3 Posted August 10, 2011 Author Share Posted August 10, 2011 personally, i wouldn't touch them with a barge pole... the supra is a big heavy car, cheap cross drilled/grooved disks have a habbit of cracking due to the manufacture process. I put tyres and brakes in the same basket - one area not to "go cheap" in, but like I said its just my oppinion. What if you dont sell I agree but the ones on the car are warped as I get a shake braking fast speed. so do need replacing. but I do not want to spend 300+ on brakes at the mo . would you say all them discs are no good or most. also when you say crack is this a quick process or we saying year down the line . Link to comment Share on other sites More sharing options...
heckler Posted August 10, 2011 Share Posted August 10, 2011 I agree but the ones on the car are warped as I get a shake braking fast speed. so do need replacing. but I do not want to spend 300+ on brakes at the mo . would you say all them discs are no good or most. also when you say crack is this a quick process or we saying year down the line . hard to say really, but I wouldnt expect them to last 1k miles, there also prone to warping (previous experience - not on the supra though!). OEM Uk disk arn't that expensive. Perhaps I've just had a bad experience of cheap disks! Link to comment Share on other sites More sharing options...
k9l3 Posted August 10, 2011 Author Share Posted August 10, 2011 they warped Link to comment Share on other sites More sharing options...
k9l3 Posted August 10, 2011 Author Share Posted August 10, 2011 hard to say really, but I wouldnt expect them to last 1k miles, there also prone to warping (previous experience - not on the supra though!). OEM Uk disk arn't that expensive. Perhaps I've just had a bad experience of cheap disks! really only 1000 you reckon like you say I suppose its how they are made. how much you reckon for oem. also what size pads would I need for the UK spec or are they same as normal. mintex pads are good enough a racing instructor I know reckons they better or as good as the ebc . he reckons ebc is overrated and not as good as people think . his words not mine Link to comment Share on other sites More sharing options...
heckler Posted August 10, 2011 Share Posted August 10, 2011 really only 1000 you reckon like you say I suppose its how they are made. how much you reckon for oem. also what size pads would I need for the UK spec or are they same as normal. mintex pads are good enough a racing instructor I know reckons they better or as good as the ebc . he reckons ebc is overrated and not as good as people think . his words not mine I paid about £160 (pair) ish for mine - pads personal preference really - I've always used Chris Wilson pads there about £80 ish. Just get pads for a UK spec supra. Link to comment Share on other sites More sharing options...
Nic Posted August 10, 2011 Share Posted August 10, 2011 I agree but the ones on the car are warped as I get a shake braking fast speed. Are you sure it's the disc? A worn wheel bearing can also cause vibration under braking. Link to comment Share on other sites More sharing options...
Nic Posted August 10, 2011 Share Posted August 10, 2011 Smaller Brakes Front - Calipers 2pot/Discs 296mm x 32mm Rear - Calipers 1pot/Discs 307mm x 16mm Larger Brakes Front - Calipers 4pot/Discs 323mm x 30mm Rear - Calipers 2pot/Discs 324 x 16mm I'd fit new OEM Toyota discs, they are the best choice IMO in terms of quality and value for money. Link to comment Share on other sites More sharing options...
k9l3 Posted August 10, 2011 Author Share Posted August 10, 2011 (edited) Ye I will get oem if I order it. the way the wheel shakes its must be the breaks. how would you know if its the bearing for sure. would just shaking the wheel for movement do it? Edited August 10, 2011 by k9l3 (see edit history) Link to comment Share on other sites More sharing options...
k9l3 Posted August 10, 2011 Author Share Posted August 10, 2011 Smaller Brakes Front - Calipers 2pot/Discs 296mm x 32mm Rear - Calipers 1pot/Discs 307mm x 16mm Larger Brakes Front - Calipers 4pot/Discs 323mm x 30mm Rear - Calipers 2pot/Discs 324 x 16mm I'd fit new OEM Toyota discs, they are the best choice IMO in terms of quality and value for money. how would I know what pads to get or are they same size. if not would you know a link to a set of mintex? Link to comment Share on other sites More sharing options...
heckler Posted August 10, 2011 Share Posted August 10, 2011 how would I know what pads to get or are they same size. if not would you know a link to a set of mintex? pads are different sizes. Judging from the mintex website they only made pads of the import. seriously, speak to chris wilson on this forum about brake pads. I use his fast road pads with oem disks (UK spec) and there awesome. Link to comment Share on other sites More sharing options...
k9l3 Posted August 11, 2011 Author Share Posted August 11, 2011 pads are different sizes. Judging from the mintex website they only made pads of the import. seriously, speak to chris wilson on this forum about brake pads. I use his fast road pads with oem disks (UK spec) and there awesome. done say that I just ordered a set of mintex I hope they fit now. I could not afford expensive pads at the moment like I say car is up for sale so not 100 percent keeping it yet even tho I just paid for coolant to be flushed and changed. and had front l.e.d's put on which I was going to put in the lights but because of problems ended up where the grill is will do a picture to show everyone then. Link to comment Share on other sites More sharing options...
