Urgent! Crank Pulley Tool
hackin_n_bashin
If you want to remove the pulley, you could wedge a breaker bar under the o/s chassis whilst connected to the pulley.
If you turn the key for about 1 or 2 seconds, it will spin the bolt off :)
Sounds dodgy....because it is, but it does work
i removed mine not to long ago used a couple of bits of screwed bar drilled a peace of flat plate and drew it of using the crank bolt worked a treat.to crack the bolt brecker bar and scaff pole with the car in a high gear dodgy but works.
  • 4 weeks later...
