Single turbo dead, need help not to do the same mistakes twice
ksbkrew
So after all, sorry for my english i'm french :D
my car is a uk spec , and i had fitted a single turbo with an OBX T04S turbo (i know this is not a good turbo )
After 300miles, i 've got a big blue smoke coming through the exhaust and at the junction between the hotside and the downpipe
i put all the stuff down to see where the problem is located , so :
-no oil in the intercooler and in the piping
-no oil in the manifold
-no oil in the intake
so the problem is coming from the turbo
i start again the car and remove the DP , to see the wheel from the hotside.
And when i idle, i can see oil leaking from the wheel
First i was thinking that the turbo is a bad one and seals 's been dead
this morning, i dissasemble the turbo and here it 's what i found :
http://img109.imageshack.us/img109/6374/img7845v.jpg
http://img834.imageshack.us/img834/1293/img7846k.jpg
http://img691.imageshack.us/img691/7259/img7848a.jpg
http://img171.imageshack.us/img171/4176/img7850i.jpg
http://img638.imageshack.us/img638/4011/img7852p.jpg
so for me , it's not the seals, it's an oil problem, the turbo hasn't been oiled and had been in too high temperatures.
I had look my oil feed line and i think that the problem is coming from here and i 'd like your help to confirm it and not make the same mistake twice with the new turbo
At the exit of the block, i 've got a restrictor like that
http://img27.imageshack.us/img27/2527/img7854u.jpg
after i've got this oil line with an -4an
http://cgi.ebay.com/ebaymotors/28-long-Mitsubishi-Turbo-Oil-Feed-Line-Aeroquip-4an-_W0QQcmdZViewItemQQhashZitem5193b9782fQQitemZ350370756655QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
and finally got the flange over the turbo to fit the line but i haven't see when i've put it that there 's a restrictor in it too.
http://img850.imageshack.us/img850/7641/img7853.jpg
so i think my problem is coming from the two restrictors i've got, there's not enough oil in the turbo.
Could you confirm me those things?
-a -4an line is enough for a single turbo or shall a need a bigger?
-do i need a restrictor in the line?
-is it better to put it at the exit of the block or at the entry of the turbo?
all help will be cool!
thanks for reading
Tom
so the solution (after replacing the turbo) is to put a full 3an line without restrictor?
i don't want to smash another one.
the next will be a T61 XS power (i need a cheap turbo to drive the car until december, after i will put a precision T61) , will it be ok with the AN3 line?
many thanks
rebuild will cost me more than buying a new unit
i 've look after new internal but can't find them anywhere
The Xs will be only temporaly , as i will switch in a few month and i'm looking only after 420whp so i thnik it will make his job for the money.
i'm a little lost in the size
i found this on ebay: an 3an hose for feed line
http://www.ebay.co.uk/itm/Turbocharger-Turbo-AN3-3AN-Oil-Feed-Feeding-Line-1m-/160602822345?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2564ac96c9
when i see the page, it indicates:
Hose Inside Diameter (in:cm)
1/8” : 3.17mm
Hose Outside Diameter (in):
1/4" 0.25 in. : 6.35mm
so inner diameter is 1/8 or 3.17mm
but i was thinking that an 3an hose was : 3/16 inch so 4.7mm not 3.17mm
what's the right thing???
because my feed line (that i've already get) has -4an fitting but when i mesures the inner diameter is very near of 1/8" so 3.17mm
can someone help me?
thanks
