J-Spec down pipe + decat
JMB
hello all,
I'm new on the forum and nowthat I already post my "presentation post", here I start with questions.
Lot of them may look stupid but I never (never) had a turbo car before (my previous was a supercharged rx8...nothing can be compare :D)
so my car (98 TT A/T) is arriving from japan and I want to remove the OEM downpipe + both cat.
I already have a boost controler (HKS) + supraStore Boost Cut Controler
suprastore told me not to remove both cat ... so as long as I have the OEM J-Spec turbos, I read one the forum that I can use a restrictor ring ... I have to buy or I can do it myself ?
I read somewhere that the LHD downpipe won't fit a RHD supra...is it true ?
thanks for the Help :)
Salut
Tape BPU t'aura toute les infos de pourquoi il ne faut pas enlever tes downpipe sans restrictor ring
Tu trouvera toutes les infos içi plutot que sur suprastore qui n'a pas trop la cote ici a juste titre
A+
( just look at sear ch section about BPU and why do not decat without RR)
(you'll find better info here than at suprastore...)
