200+ MPH Speedo
MV8
Thank you Heckler. Which do you recommend to go with your blue led backlights as id like to order those when you get them up for sale.
there always for sale ;) makes no odds really, works with both white and blue...
Just a couple of quick questions if i may. Does the metal stainless finish look ok in the night? Like are the lights/numbers clear at night? And does dust not show up easily on the stainless steel ones?
  • 3 weeks later...
do you have too calibrate the speedo when fitting these?
all the needles will need "calibrating" the speedo is the hardest to do.. as it really needs to be done while driving with a GPS speedo to get any decent reading off the speedo... having fitted several sets, I now have an electronic solution....
How could it be hard? On the other cars I've changed on its only been to place the needle as it was, and its been the correct speed everytime.
Is it different on the Supra?
I'll find out when mine come :)
because when the needle is removed, the spindle unwinds to it's natural stop point which is about the 5 o'clock position
Hecklers right... I made a right pigs ear of mine.. speedo is out by 15mph... therefore will be asking Mr awesome (heckler) to do mine when its in his possession a few days from now :) .. That ok Si ?
On another note Si .. should be sending out all the bits and making payment monday/tuesday :) ... cant wait ..
The question was if I cant simply take a plier and hold the needle in place when removing it.
You apparently didnt do any research before changing and it came out like shit, I choose to ask questions and get it right the first time. PITA
Easy now... You realise PITA means "pain in the ass" .. I was referring to the job .. Not you.
No need to get sarcastic, its dam near impossible to get anything on the spindle and put a new facia on at the same time, theres not enough space/clearance.
Sorry m8, my bad! Hope you dont think I'm an asshole.
I'll have a go at this when the new dials come so hopefully I wont have to dial them in too much.
Again, sorry.
