BPU raise boost?
Guest George89
Guest George89
I have just finished my engine conversion from NA-TT and the car is running 0-9 bar. It has a restrictor ring and a NA HKS hi-power silence exhaust which i understand is smaller then the TT ones. Whats the best way too get too 1.2 bar? if i take the restrictor ring out would it overboost? when my cat back is smaller then TT? or should i make a bigger whole in the ring?
Guest George89
i will be getting one next month, but for the mean time could i just make my restrictor ring larger? anyone know what dimensions i need for 1.2/1.1 bar
Guest George89
a manual boost controller will work fine,fit one 1st before you open you rr
Ok i set my manual boost controller fully open and i don't see a difference, should i close it too see boost gains?
Oke so the gearbox will withstand the extra gains in bhp by going BPU, nice one George, try to get the diameters of your system exhaust sorted,
3'' straight through would be perfect for a bpu'd supra, when with a 3'' straight through the boost will run over 1,2 bar get an 1,2 bar restrictor ring in your system exhaust to prevent over boosting,
Guest George89
I just when out and turn my manual boost controller alway the way down (-) and the boost when up to 1.5 bar! it looks like its vise versa, + is less boost. So now i set it too 1.1 bar until i get a EBC
