Black_Supra Posted February 8, 2011 Share Posted February 8, 2011 Hey Guys, i got a 19 Row Oil cooler and wanna install it, just need a fitting kit but i got some problems with it. I want to Install a Thermostat + Oiltemp + Oilpressure ... With a sandwich plate i could install the sensors but where i can install the 2 lines for the oil cooler. I found sandwich plates with 4 holes, would it be possible to install the 2 sensors and 2 lines for the oil cooler on it or is the diameter of the holes to small for a oilcooler, i think yes, right ? Fabian Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 9, 2011 Share Posted February 9, 2011 I can supply a thermostatic sandwich plate for decent size (-10 or -12) cooler lines. Put the temp sender in a sump plug adaptor, and the pressure sender in a drilled and tapped oil filter adaptor bolt, or buy the ready drilled and tapped Lexus one. I can supply all of these, too. Link to comment Share on other sites More sharing options...
