Guest wantthatone Posted January 27, 2011 Share Posted January 27, 2011 hi, i see some of the members on here have used these to fit gauges, can any one advise if this is an easy task & what if any parts are used to hold the gauge in place? or do you suggest another way? thanks:) Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted January 27, 2011 Share Posted January 27, 2011 Need to use 60mm gauges mate. I took the panel off, eased off the back of the vent to get the ball out, carefully split the ball and took the blades out. Cut out the bars at the rear to let you access the wires of the gauge if needed. In there is a little plastic gasket around the outlet, cut that down to be a good fit around the gauge, then 1 layer of masking or insulation tape, and push the gauge into the ball. Refit the ball into the panel, wire up, refit the panel and hey presto. Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted January 27, 2011 Share Posted January 27, 2011 brilliant cheers mate.... Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted January 27, 2011 Share Posted January 27, 2011 typical, there 52mm,,, grrrr. where would be a good place to mount these? Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted January 27, 2011 Share Posted January 27, 2011 Clock? almost a straight replacement. or A pillar pod Quote Link to comment Share on other sites More sharing options...
