w41k3r Posted January 24, 2011 Share Posted January 24, 2011 Had a bit of spare time today so decided to see how my gauges would look in place of the clock and the heater vent, a/f ratio gauge fitted fine but my 60mm boost gauge is a fraction to small did anybody else have this problem? any ideas how to get it sitting more flush ? Link to comment Share on other sites More sharing options...
SupraShaun Posted January 24, 2011 Share Posted January 24, 2011 Hollow out the vent thing that was in that hole, then secure it in that. You'll be able to move it around then too (like the original vent). Link to comment Share on other sites More sharing options...
w41k3r Posted January 24, 2011 Author Share Posted January 24, 2011 yeah i just found this pic now does the vent not just come apart ? or do you just have to butcher it Link to comment Share on other sites More sharing options...
jackso11 Posted January 24, 2011 Share Posted January 24, 2011 Take the fan ball to pieces and put the guage inside the ball. Thats how you get a good fit. Also, means you can move it if the sun is glaring Link to comment Share on other sites More sharing options...
SupraShaun Posted January 24, 2011 Share Posted January 24, 2011 I butchered mine Link to comment Share on other sites More sharing options...
w41k3r Posted January 24, 2011 Author Share Posted January 24, 2011 I assume this fan thing comes apart but at the moment im leaning towards the suprashaun style of butchering it Link to comment Share on other sites More sharing options...
SupraShaun Posted January 24, 2011 Share Posted January 24, 2011 Im pretty sure I still have mine hanging around at home. I moved my gauge as I have a pillar pod now - I'll have a look when I get home. Link to comment Share on other sites More sharing options...
j_jza80 Posted January 24, 2011 Share Posted January 24, 2011 The fins push out of the vent fairly easily. If you find it's a bit loose or ill fitting, wrap the hidden bit of the gauge with a bit of duct tape Link to comment Share on other sites More sharing options...
trinitom Posted January 24, 2011 Share Posted January 24, 2011 you can try what i would be doing with my Greddy a-pillar 60mm holes, and that would be cutting 2 bits of Perspex with the right size for the pods and gauges, then you can paint it to look better. Link to comment Share on other sites More sharing options...
monsween Posted January 24, 2011 Share Posted January 24, 2011 Yup it comes apart pretty easy Mine sits pretty funny tho because of the angle of the vacuum hose, Link to comment Share on other sites More sharing options...
w41k3r Posted January 24, 2011 Author Share Posted January 24, 2011 well went back to my dash and finished the install thanks to the ideas i sorted the heater vent idea because the a/f ratio didnt sit flush i made the boost gauge sit similar doesnt look to bad imo Link to comment Share on other sites More sharing options...
